QUADGOTRANSPARENT system variable
Quad go transparent
Specifies if the quad starts should go transparent while the mouse is moving away from it.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
Off
Possible values:
Off (0): Don’t go transparent
On (1): Go transparent
