QUADHIDEMARGIN system variable
Quad hide margin
Specifies the width of a margin around the quad. As long as the mouse keeps moving inside this margin, the quad will stay visible. It will gradually go transparent if QuadGoTransparent is on. As soon as the mouse movement stops, or when the mouse is moved beyond the margin, the quad will disappear.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Default value: |
50 |
