QUADROLLOVERDELAY system variable
Quad rollover delay
Specifies the delay after which rollover properties appear on the quad.
Note: This is ignored in rollover-only mode (when QUADDISPLAY is off and ROLLOVERTIPS is
on - in that case, the rollover properties are always shown immediately)
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 10000 |
Default value: |
0 |
