RE_INIT system variable
Reinitialize Aliases
Reinitializes the digitizer, digitizer port and/or reloads PGP file (command aliases). The value is stored as a bitcode using the sum of the values of all selected options.
Read-only
Tipo: | Breve |
Salvato in: | Non salvato |
Gamma: |
0 to 21 |
Valore predefinito: |
0 |
Possibili opzioni: |
1: Digitizer input/output port reinitialization 4: Digitizer reinitialization 16: PGP file reinitialization (reload) |
