RE_INIT system variable
重新起始别名
Reinitializes the digitizer, digitizer port and/or reloads PGP file (command aliases). The value is stored as a bitcode using the sum of the values of all selected options.
只读
Type: | Short |
Saved in: | Not saved |
Range: |
0 to 21 |
Default value: |
0 |
Possible options: |
1: Digitizer input/output port reinitialization 4: Digitizer reinitialization 16: PGP file reinitialization (reload) |
