RE_INIT system variable
Reinitialize Aliases
Reinitializes the digitizer, digitizer port and/or reloads PGP file (command aliases). The value is stored as a bitcode using the sum of the values of all selected options.
Read-only
| Type: | Short |
| Saved in: | Not saved |
| Range: |
0 to 21 |
| Default value: |
0 |
| Possible options: |
1: Digitizer input/output port reinitialization 4: Digitizer reinitialization 16: PGP file reinitialization (reload) |
