REDSDKLINESMOOTHING system variable
线平滑
Specifies whether line smoothing is enabled for 3d rendering modes. Has no effect if anti-aliasing is on.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | Off |
Possible values: |
Off (0): Line smoothing off On (1): Line smoothing on |
