REFEDITLOCKNOTINWORKSET system variable
Refedit lock
Specifies whether entities that are not in the working set will be locked during the RefEdit command. Locked entities are seen, but cannot be edited.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Lock entities not in working set off On (1): Lock entities not in working set on |
