REFEDITLOCKNOTINWORKSET system variable
参照编辑锁护
Specifies whether entities that are not in the working set will be locked during the RefEdit command. Locked entities are seen, but cannot be edited.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | Off |
Possible values: |
Off (0): Lock entities not in working set off On (1): Lock entities not in working set on |
