REGENMODE system variable
Regeneration mode
Toggles the automatic regeneration of the drawing On/Off. BricsCAD will regenerate the display automatically when REGENMODE is On, but in a few cases a forced regeneration of the drawing might be necessary. This is done by the REGEN command.
Type: | Boolean |
Saved in: | Drawing |
Default value: | On |
Possible values: |
Off (0): Turn off REGENAUTO command On (1): Turn on REGENAUTO command |
