REGEXPAND system variable
Registry paths expanding type
Specifies type of storing paths in a registry (absolute or expandable). The new value is applied after application re-start.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | On |
Valori possibili: |
Off (0): Don’t store paths in a portable format using environment variables On (1): Store paths in a portable format using environment variables |
