RENDERMATERIALSPATH system variable
Render materials directory path
Specifies the folder(s) in which BricsCAD should look for user created render material files.
Solo-BricsCAD
Tipo: | Stringa |
Salvato in: | Registro di sistema |
Solo-BricsCAD
Tipo: | Stringa |
