REPORTPANELMODE system variable
Report panel mode
Specifies the mode of report panel. Applicable only for commands which support it.
- Classic: Report panel has its classic appearance as dockable window.
- Modern: Report panel is a transparent window.
- Hidden: Report panel is a transparent window that is hidden into the status bar.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: |
Area di Lavoro |
Gamma: |
0 to 2 |
Valore predefinito: |
2 |
Valori possibili: |
0: Classic 1: Modern 2: Hidden |
