REVCLOUDMAXARCLENGTH system variable
Revision cloud default maximum arc length
Specifies the default maximum arc length for revision clouds. The maximum arc length is multiplied by the value of the DIMSCALE variable.
Type:
Real
Saved in:
Registry
Default value:
0.375
