REVCLOUDMINARCLENGTH system variable
修订云形默认最小弧长
Specifies the default minimum arc length for revision clouds. The minimum arc length is multiplied by the value of the DIMSCALE variable.
Type: | Real |
Saved in: | Registry |
Default value: |
0.375 |
