ROLLOVERSELECTIONSET system variable
候选物选取设置
Specifies if/how the rollover tips show properties of hovered selection set. (setting the value to 2 can be slow on large selection sets).
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 2 |
Default value: |
2 |
Possible values: |
0: 没有选择集属性 1: 一般选择集属性 2: 所有选定实体共享的属性 |
