RUNASLEVEL system variable
Run as license level
Specifies at which license level to run BricsCAD. The new level will be in use after restarting. If the purchased license level is lower than RUNASLEVEL, RUNASLEVEL is ignored.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: |
Registro di sistema |
Gamma: |
0 to 5 |
Valore predefinito: |
5 |
Valori possibili: |
0: Lite 1: Pro 2: Platinum (Obsolete) 3: BIM 4: Mechanical 5: Ultimate |
