RUNASLEVEL system variable
以许可证等级运行
Specifies at which license level to run BricsCAD. The new level will be in use after restarting. If the purchased license level is lower than RUNASLEVEL, RUNASLEVEL is ignored.
BricsCAD only
Type: | Short |
Saved in: |
Registry |
Range: |
0 to 5 |
Default value: |
5 |
Possible values: |
0: Lite 1: Pro 2: Platinum (Obsolete) 3: BIM 4: 机械(M) 5: 旗舰版 |
