SAFEMODE system variable
Safe mode
Specifies if executable code can be loaded and executed in the current session. Starting in a clean environment can help to eliminate potential causes of a crash.
Read-only
Type:
Boolean
Saved in:
Not saved
Default value:
Off
Possible values:
Off (0): Allows executable code run
On (1): Does not allow executable code to run
