SAVEFIDELITY system variable
Save fidelity
Specifies whether the drawing is saved with visual fidelity. Controls whether the current display of the drawing is preserved when opened in a program that does not support annotative entities.
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Gamma: |
0 to 1 |
Valore predefinito: |
On |
Valori possibili: |
Off (0): Don’t save with visual fidelity On (1): Save with visual fidelity |
