SAVEFIDELITY system variable
Save fidelity
Specifies whether the drawing is saved with visual fidelity. Controls whether the current display of the drawing is preserved when opened in a program that does not support annotative entities.
Type:
Boolean
Saved in:
Registry
Range:
0 to 1
Default value:
On
Possible values:
Off (0): Don’t save with visual fidelity
On (1): Save with visual fidelity
