SAVEFORMAT (variable système)
Format enregistrement
Spécifie le format d’enregistrement par défaut d’un dessin.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
1 à 39
Default value:
4
Possible values:
1: DWG 2018
2: DXF 2018
3: DXF 2018 binaire
4: DWG 2013
5: DXF 2013
6: DXF Binaire 2013
7: DWG 2010
8: DXF 2010
9: DXF 2010 binaire
10: DWG 2007
11: DXF 2007
12: DXF 2007 binaire
13: DWG 2004
14: DXF 2004
15: DXF 2004 binaire
16: DWG 2000
17: DXF 2000
18: DXF 2000 binaire
19: DWG R14
20: DXF R14
21: DXF R14 binaire
22: DWG R13
23: DXF R13
24: DXF R13 binaire
25: DWG R11/R12
26: DXF R11/R12
27: DXF R11/R12 binaire
28: DXF R10
29: DXF R10 binaire
30: DXF R9
