SAVETIME system variable
保存时间间隔
Specifies the interval, in minutes, for automatic saves. If set to zero, automatic saves are turned off. Values between 0 and 240 are accepted.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 240 |
Default value: |
60 |
Possible values: |
0: Turn off automatic saving 1 - 240: Saves the drawing at intervals specified (in minutes) |
