SAVETIME system variable
Save time interval
Specifies the interval, in minutes, for automatic saves. If set to zero, automatic saves are turned off. Values between 0 and 240 are accepted.
Type:
Short
Saved in:
Registry
Range:
0 to 240
Default value:
60
Possible values:
0: Turn off automatic saving
1 - 240: Saves the drawing at intervals specified (in minutes)
