SECTIONSETTINGSSEARCHPATH system variable
Section settings search path
Specifies the folder(s) in which BricsCAD® should look for BIM section styles, BIM tag styles and drawing customizations. Search paths are separated by a semicolon (;).
Solo-BricsCAD
Tipo: |
Stringa |
Salvato in: |
Registro di sistema |
Valore predefinito: | " " |
