SECTIONSETTINGSSEARCHPATH system variable
Section settings search path
Specifies the folder(s) in which BricsCAD® should look for BIM section styles, BIM tag styles and drawing customizations. Search paths are separated by a semicolon (;).
BricsCAD only
Type: |
String |
Saved in: |
Registry |
Default value: | " " |
