SECTIONSETTINGSSEARCHPATH system variable
Section settings search path
Specifies the folder(s) in which BricsCAD should look for BIM section styles, BIM tag styles and drawing customizations. Search paths are separated by a semicolon (;).
BricsCAD only
Type:
String
Saved in:
Registry
Default value: " "
