SECTIONSHEETSETTEMPLATEIMPERIAL system variable
Section sheet set template imperial
Sheetset file (dst) that will be used as a template when a new sheetset is created on generating sections when MEASUREMENT is 0 (imperial). The default value is "BIM-section-imperial.dst" in the {SheetSetTemplatePath} folder.
BricsCAD only
Type: |
String |
Saved in: |
Registry |
Default value: | BIM-section-imperial.dst |
