SECTIONSHEETSETTEMPLATEMETRIC system variable
Section sheet set template metric
Sheetset file (dst) that will be used as a template when a new sheetset is created on generating sections when MEASUREMENT is 1 (metric). The default value is "BIM-section-metric.dst" in the {SheetSetTemplatePath} folder.
Solo-BricsCAD
Tipo: |
Stringa |
Salvato in: |
Registro di sistema |
Valore predefinito: | BIM-section-metric.dst |
