SECTIONSHEETSETTEMPLATEMETRIC system variable
Section sheet set template metric
Sheetset file (dst) that will be used as a template when a new sheetset is created on generating sections when MEASUREMENT is 1 (metric). The default value is "BIM-section-metric.dst" in the {SheetSetTemplatePath} folder.
BricsCAD only
Type:
String
Saved in:
Registry
Default value: BIM-section-metric.dst
