SECTIONSHEETSETTEMPLATEMETRIC system variable
Section sheet set template metric
Sets the sheetset file (dst) that will be used as template when a new sheetset is created on generating sections when MEASUREMENT is 1 (metric). The default file is BIM-section-metric.dst, which can be found in the {SheetSetTemplatePath} folder.
BricsCAD only
Type: |
String |
Saved in: |
Registry |
Default value: | BIM-section-metric.dst |
Note: The SECTIONSHEETSETTEMPLATEMETRIC system variable is only available for BIM and Ultimate license levels.
