SELECTIONAREAOPACITY system variable
选取区域透明度
Specifies the transparency of the selection area (lower value = more transparent). This is only in effect when SELECTIONAREA setting is On.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 100 |
Default value: |
25 |
