SELECTIONAREAOPACITY system variable
Selection area opacity
Specifies the transparency of the selection area (lower value = more transparent). This is only in effect when SELECTIONAREA setting is On.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 100 |
| Default value: |
25 |
