SELECTIONMODES system variable
Selection modes
Specifies which subentities or detected boundaries, should be highlighted in selection preview. The value is stored as a bitcode using the sum of the values of all selected options. While in selection preview, you can use the TAB key to cycle through the included subentity types and detected boundaries.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Area di Lavoro |
Gamma: |
0 to 15 |
Valore predefinito: |
0 |
Possibili opzioni: |
1: Select edges 2: Select faces 4: Select detected boundaries 8: Select vertices |
