SELECTIONMODES system variable
选取模式
Specifies which subentities or detected boundaries, should be highlighted in selection preview. The value is stored as a bitcode using the sum of the values of all selected options. While in selection preview, you can use the TAB key to cycle through the included subentity types and detected boundaries.
BricsCAD only
Type: | Short |
Saved in: | Workspace |
Range: |
0 to 15 |
Default value: |
0 |
Possible options: |
1: Select edges 2: 选取面 4: 选取检测的边界 8: 选择顶点 |
