SELECTIONPREVIEW system variable
选取预览的显示
Specifies in which cases entities are highlighted when the pickbox cursor hovers over them: when no commands are active or when a command prompts for entity selection. The value is stored as a bitcode using the sum of the values of all selected options.
When QUADDISPLAY is on, the value of the SELECTIONPREVIEW option 'When no commands are active' will be overruled, and treated as 'ON'.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 3 |
Default value: |
3 |
Possible options: |
1: 在没有命令作用时 2: 当对象选取命令指示时 |
