SELECTSIMILARMODE system variable
Match options for SELECTSIMILAR
Specifies which properties must match for an entity of the same type to be selected with SELECTSIMILAR. For this command to operate as intended, at least one property must be turned on. When all properties are turned off, this command selects only the entity(ies) you pick at the 'Select entities' prompt. The value is stored as a bitcode using the sum of the values of all selected options.
Tipo:
Breve
Salvato in:
Registro di sistema
Gamma:
0 to 255
Valore predefinito:
130
Possibili opzioni:
0: Object type
1: Color
2: Layer
4: Linetype
8: Linetype scale
16: Lineweight
32: Plot style
64: Object style
128: Name
