SELECTSIMILARMODE system variable
SELECTSIMILAR 的相符选项
Specifies which properties must match for an entity of the same type to be selected with SELECTSIMILAR. For this command to operate as intended, at least one property must be turned on. When all properties are turned off, this command selects only the entity(ies) you pick at the 'Select entities' prompt. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 255 |
Default value: |
130 |
Possible options: |
0: Object type 1: Color 2: Layer 4: Linetype 8: Linetype scale 16: Lineweight 32: Plot style 64: Object style 128: Name |
