SETBYLAYERMODE system variable
Options for SETBYLAYERMODE
Specifies which layer properties would be applied by SETBYLAYER command.
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: |
0 to 255 |
Valore predefinito: |
255 |
Valori possibili: |
0: None 1: Color 2: Linetype 4: Lineweight 8: Material 16: Plot style 32: ByBlock 64: Blocks 128: Transparency |
