SETBYLAYERMODE system variable
Options for SETBYLAYERMODE
Specifies which layer properties would be applied by SETBYLAYER command.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 255 |
Default value: |
255 |
Possible values: |
0: None 1: Color 2: Linetype 4: Lineweight 8: Material 16: Plot style 32: ByBlock 64: Blocks 128: Transparency |
