SHEETSETAUTOBACKUP system variable
Sheet set automatic backup
Specifies whether a backup file is created whenever a sheet set file is opened. The backup files have the same name as the sheet set file but with a '*.ds$' extension.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: | On |
Valori possibili: |
Off (0): Don’t create backup files On (1): Create backup files |
