SHEETSETAUTOBACKUP system variable
Sheet set automatic backup
Specifies whether a backup file is created whenever a sheet set file is opened. The backup files have the same name as the sheet set file but with a '*.ds$' extension.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | On |
Possible values: |
Off (0): Don’t create backup files On (1): Create backup files |
