SHEETSETTEMPLATEPATH system variable
Sheet Set template path
Specifies the path to the Sheet Set Templates folder. The default path is: \Users\<user name>\AppData\Local\ Bricsys\BricsCAD\Vxx\en_US\Templates\Sheet Sets
Type: |
String Standard |
Saved in: | Preference |
