SHORTCUTMENU system variable
Shortcut menus
Specifies the status of the DEFAULT, EDIT and COMMAND shortcut menus. The value is stored as a bitcode using the sum of the values of all selected options.
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: |
0 to 31 |
Valore predefinito: |
19 |
Possibili opzioni: |
0: Disable all Default, Edit, and Command mode shortcut menus 1: Enable Default mode shortcut menus 2: Enable Edit mode shortcut menus 4: Enable Command mode shortcut menus (available whenever a command is active) 8: Enable Command mode shortcut menus only when command options are currently available from the Command line 16: Enable display of a shortcut menu when the right button on the pointing device is held down longer |
