SHORTCUTMENU system variable
Shortcut menus
Specifies the status of the DEFAULT, EDIT and COMMAND shortcut menus. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Registry
Range:
0 to 31
Default value:
19
Possible options:
0: Disable all Default, Edit, and Command mode shortcut menus
1: Enable Default mode shortcut menus
2: Enable Edit mode shortcut menus
4: Enable Command mode shortcut menus (available whenever a command is active)
8: Enable Command mode shortcut menus only when command options are currently available from the Command line
16: Enable display of a shortcut menu when the right button on the pointing device is held down longer
