SHOWDOCTABS system variable
Tabs visibility
Toggles showing of the document tabs On/Off. You can make the drawing area larger by hiding the document tabs from the user interface.
Solo-BricsCAD
Tipo:
Booleana
Salvato in:
Registro di sistema
Valore predefinito:
On
Valori possibili:
Off (0): Don’t make tabs visible
On (1): Make tabs visible
