SHOWLAYERUSAGE system variable
Layer Usage
Shows information about layer usage in the layer presentation panel. In the column Current, the Layer Usage icons indicate when viewport settings for the current layout and paper space viewport are different from model space settings:
: Current layer with viewport overrides.
: Layer with viewport overrides.
: Empty layer with viewport overrides.
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Do not display Layer Usage On (1): Display Layer Usage |
