SINGLETONMODE system variable
Singleton mode
Switch to control whether one or more instances of BricsCAD can run simultaneously. When set to Off, only a single instance of BricsCAD can run. When set to On, you can launch two or more copies of BricsCAD at the same time.
Solo-BricsCAD
Tipo:
Booleana
Salvato in:
Preferenza
Valore predefinito:
OFF
Valori possibili:
Off (0): Singleton mode off
On (1): Singleton mode on
