SINGLETONMODE system variable
Singleton mode
Switch to control whether one or more instances of BricsCAD can run simultaneously. When set to Off, only a single instance of BricsCAD can run. When set to On, you can launch two or more copies of BricsCAD at the same time.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
Off
Possible values:
Off (0): Singleton mode off
On (1): Singleton mode on
