SKPOLY system variable
Sketch poly
Specifies the entity type (lines or polylines) created by the SKETCH command.
Type:
Boolean
Saved in:
Drawing
Default value:
0
Possible values:
Off (0): Generate lines
On (1): Generate polylines
